Phone has a pink shade on 3/4 of the screen?
How can I fix this issue?
Questa è una buona domanda?
Rinku Master this sounds like a bad display since it is only showing on parts of it. Most likely will require a new display assembly. Sostituzione schermo Samsung Galaxy Note9
Hi,
Just to add to the answer above, try starting the tablet in safe mode just to eliminate the remote possibility that it is a software problem that is the cause of the problem.
If it also display the same when in safe mode try a screen replacement as suggested above.
If you screen is yellow and screen is not visible clearly and brightness bar adjustment is a problem, and unable to view or see the screen with high resolution,
Many people feel it's a display problem and then they replace the display,
But it's 100% not a display problem, it's software issue on samsung galaxy note 9 device.
Solution: Please use "OLED Saver" app from Google,
Once download > Install> Enable OLED Saver
Then please observe the difference on display, before and after.
And we can able to watch HDR videos on youtube on SAMOLED resolution after installing OLED Saver app.
Please try, it will not cause any issue on the mobile, i am using from last 1 year. If not satisfied you can uninstall the app.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 783
