Salta al contenuto principale
THINKPAD T520: prestazioni e portabilità di alto livello.
Computer is on but screen black?
My laptop worked yesterday. Today I attempted to turn it on as usual, pressing the power button. It made all the usual noises. On startup, It makes a beeping noise, but that is normal. Today the screen is completely black. I can tell it’s on. The fans are running and the light is on. Still, the screen is black.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
DiamondWolf Gaming  connect an external monitor. If that works you know the issue is with your display. If it does not then it could be a GPU (motherboard) issue. Also while your computer is on, in a darkened room, shine a flashlight beam at an angle against the screen. See if you can make out your menu etc. If so you know it is a backlight issue.
Punteggio 1
Aggiungi la tua risposta
DiamondWolf Gaming sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 13
Tutti i Tempi: 632
