Salta al contenuto principale
Produttori di componenti per biciclette.
Bike chain falling problem
I go out with my GT Bikes and having a chain falling problem. I have to fix it every 5 to 10 minutes, which is a very annoying thing.
I hope I can get a good solution from professionals.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
Check this article hope this might help you
https://papasroadtrip.com/how-to-tighten...
Or you may purchase a new one.
Punteggio 2
3 Commenti:
Let me check and thanks for quick response.
da
Ok good luck.
da
check if teeth on cogs aren't wore or bent and change them if needed - check if chain is too loose- if it is tighten or change it
da
The chain needs to be greased or get a new chain
Punteggio 1
Aggiungi la tua risposta
george_michael sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 46
Tutti i Tempi: 705
