Salta al contenuto principale
Smartphone Android prodotto da Samsung electronics introdotto sul mercato il 2 dicembre 2015.
58 Domande Visualizza tutte
My Samsung A5 2016 only turns on for a few seconds
It can only turn on while plugged into the charger, but it only turns on for a few seconds before shutting down. It can’t be turned on by pressing the power button, and while it’s plugged in it says that the battery is 100% charged but that wasn’t the actual percentage before this happened (34%). When I managed to turn it on and unlock my phone and removed the cable, the device just shutdown like when it reaches 0%. Is this a battery problem or something else? It’s been stuck like this for a few days and I need help!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @cortisol ,
I suggest that you replace the battery and then re-evaluate the problem. It may be that a faulty battery is causing problems with the normal operation of the phone when the charger is connected.
Here’s the ifixit Sostituzione batteria Samsung Galaxy A5 (2016) guide that may help.
Punteggio 1
Aggiungi la tua risposta
Isabel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 138
