Salta al contenuto principale
Le cuffie Astro A40 TR sono un dispositivo audio rilasciato nell'agosto 2015, identificato dal numero di modello 3AS48-XOU9N-601
Sound is severely distorted
One day I was playing rust, and then I looked left at my dog, and it tugged on the wire a little bit and then it sounded as if my astros were half plugged in, they were fully plugged in. I tried unplugging them or using them in a different device, but nothing worked. I could hear a little bit of sound, but it was severely muffled and distorted. Please help.
Questa è una buona domanda?
Punteggio 0
1 Commento
Probably bad sound cables or bad speakers
da
Aggiungi un commento
1 Risposta
Risposta più utile
@nathanfonk sounds like you pulled some wires either fully off the jack or it’s partially loose and they are shortening the sound out. Hence the distortion. My suggestion is that you open up the jack and check it out. Should be a straightforward replacement
Punteggio 1
Aggiungi la tua risposta
Nathan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 2,243
