Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e soluzione problemi per il sistema Logitech Z333 Bold Sound.
No sound from speaker
My logitech Z333 speakers produces no sound at all. Found that the problem is within the volume knob which is probably due to a loose connection in the main connectors. I've tried cleaning and reconnecting the connectors which works temporarily. And rotating the volume knob does produce some scratchy sound. I've attached some pictures and video link for the problem. Please help!
Immagine
Immagine
Immagine
https://vimeo.com/455476726
Questa è una buona domanda?
Punteggio 0
1 Commento
Mine has died as well,but mine didn't have a problem with sound,it was with controling the on/off and when the switch was off,the amp started buzzing...i just shorted the L-out ,R-out and VOL-line or VC-power (red wire,not orange). it just work with 100% power all the time...you might want to isolate all the other wires-if shorted it will distrupt the signal and start buzing.
da
Aggiungi un commento
2 Risposte
Risposta più utile
@ayan_4u it all seems to be pointing toward a bad potentiometer (volume control). Instead of the video, post some good pictures of the board (front and back) with your question. Replacing it will most likely fix this issue
Punteggio 1
all jokes aside… make sure the volume controller is actually turned on… yes… im a idiot
Punteggio 0
Aggiungi la tua risposta
Ayan Haldar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 3,615
