Salta al contenuto principale
La Nvidia Shield TV 1ª Generazione, prodotta da Nvidia, è un lettore multimediale digitale basato su Android TV che consente lo streaming in 4K HDR, il gioco tramite GeForce NOW, l'uso di giochi Android esclusivi e lo streaming di giochi da PC dotati di GeForce GTX verso la TV. Questa pagina include informazioni di riparazione per il numero di modello P2571.
Nvidia shield tv remote not working
I have two 2017 Nvidia shield tvs. Both remote controls stopped working. I installed new batteries in each and that did not fix the problem.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hi Edward,
I have the Nvidia Shield TV 1st gen.
The following is more of a workaround than a true fix. I often experience the same issue. I can eventually get the remote working if I leave it on charge for a while, then try syncing it to the Nvidia again. Sometimes I have to connect the remote to the Shield TV via a usb cable to get it to recognize the remote again. I picked up the newer version of the remote (which works much better and uses AAA batteries :-) The only thing that disappointed me about the new remote is it doesn’t have a 3.5mm headphone jack, so you can’t use it to connect your headphones. I constantly have connection problems with the old remote, and old controller, so I just use the new remote with a pair of bluetooth headphones instead. If I want to play a game, I’ll just connect one of my Xbox One controllers, which work great, except their headphone jack doesn’t work with the Nvidia Shield TV.
Hope this helps.
Punteggio 0
Aggiungi la tua risposta
Edward Farr sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 16
Tutti i Tempi: 1,363
