Salta al contenuto principale
Rilasciato da Dell intorno al 2009, l'E2310H è un monitor da 23 pollici con una risoluzione di 1920x1080 pixel.
Monitor lost power suddenly
During work, my E2311H got black and I’ve no chance to power on again.
Is there any spare part to check or anything else I can do myself to get it back to work.
Greetings
Questa è una buona domanda?
Punteggio 3
2 Commenti
Hi @lassegismo
What I can suggest if it is not under warranty, to open out and check on the power supply voltages.
normally i can think of, either power supply board faulty or mainboard faulty which causes this.
do you have a multimeter with you?
da
@augustine yes i check the power supply and there is 18.5 autput for both boards but the backlight plug have no power i found 2 blown 25v 220 capacitors and change it but still not working
da
Aggiungi un commento
1 Risposta
Risposta più utile
If there is still no backlight voltage, check the PSU diodes with the diode function of a DVM. If all of them check OK, check the transistors the same way = they are just two diodes b to e and b to c. I'm betting on diodes.
Punteggio 2
Aggiungi la tua risposta
Lasse Gismo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 18
Ultimi 30 giorni: 50
Tutti i Tempi: 929
