Salta al contenuto principale
The Kushlan Cement Mixer 1000DD-WB is a direct drive cement mixer with a 1.5-horsepower direct-drive motor. The mixer's polyethylene drum can hold up to 10 cubic feet or about 800 pounds of wet cement.
How to remove motor and gearbox from barrel?
1000ddwd kushlan mixer. Replacement gearbox received. Can't get the old box off the barrel. Have already removed the giant bolt in the spindle that should have freed the whole assembly. Do I have to tear this thing down to the nuts?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Don’t know if this helps or not but here are the gear motor assembly instructions section of the user manual.
Punteggio 1
Aggiungi la tua risposta
Rob Turner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 703
