Salta al contenuto principale
Modello M8407 / processore G4 a 550 o 667 MHz
Question mark folder strange issue
I have a G4 titanium that has a strange issue. I have a working hard drive in it. When I put it into target disk mode, I can boot other systems off the hard drive. When I try to boot the machine itself it gives a question mark folder. I have system 9 and OS X tiger installed on it. When I press alt at startup it shows only the OS X install. Clicking on it just resets the boot selector. Same thing with 10.3 and a cd. What should I do? Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Reaching back through the cobwebs to the very back room of my brain, I find a pile of papers half faded and out of sorts with no order. So as I piece the sheets back in some as-semblance of order…
I think I remember Tiger offered dual boot within its self. No true dual partition so you could run older OS-9 apps within it. Some people also did a proper dual boot setup as well, that’s when you setup the drive with two partitions completely isolating the OS and app spaces.
So the fact you see only the one startup disk is not unexpected.
As for your question mark always showing up.
This is caused when the PRAM battery has died! I hope you like the game of finding Waldo as we have a bit of a hunt to find it!
Follow this guide to get the optical drive out of your system Sostituzione lettore DVD PowerBook G4 Titanium Onyx then pick up from Step 6 from this guide Sostituzione batteria PRAM PowerBook G4 in Titanio DVI. Lift the battery board fully out so you can get to the battery.
Immagine PowerBook G4 Titanium Onyx Lettore DVD
Guida
Difficoltà:
Moderato
Immagine PowerBook G4 Titanium DVI Batteria della PRAM
Guida
Difficoltà:
Moderato
Punteggio 1
3 Commenti:
I would never have thought to replace the replace the battery, Apple computers don’t make much sense! Thank you I will open it once more and replace the battery see how it goes. Thank you
da Condividi
@idintfixit - Don't forget to score & accept the answer if you're set!
da Condividi
its the next day, got a new battery and it actually worked! crazy! thank you!
da Condividi
Aggiungi la tua risposta
Mihai Paun sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 28
Tutti i Tempi: 596
