FnLock Led indicator is not functioning
Although the FnLock key is functioning there is a spot in which a light is supposed to shine when FnLock is on and it does not. I have tried reinstalling drivers, and am lead to believe this is a hardware issue.
Lenovo Legion 5-15
Questa è una buona domanda?
9 Commenti
Hey I kind of have the same problem. Did you manage to get it fixed?
da Arsalan Ali Condividi
I’m having a similar issue. I first noticed that the Fn lock indicator light wasn’t turning off when pressing Fn+Esc. I decided to check for system updates and found a BIOS update (FSCN13WW) was available. While attempting to install it, the process failed on boot with an error message saying that the BIOS was incompatible with the system. Lenovo Vantage shows that it was successfully installed, however.
After that, the Fn lock LED does not come on although the Fn lock is being activated/deactivated. Num Lock led works fine.
da Christopher Chen Condividi
I had the same problem and tried searching for a solution. Try to run the LenovoUtility app. if not installed, install it from the microsoft store
da gabriel.cabigting Condividi
I first tried installing it from the lenovo website; that did not work. . Installing the vantage app from the microsoft store fixed the problem.
@gabriel.cabigting installing the LenovoUtility app fixed everything. Thanks a lot!!
da Kevin Giovanni Condividi
Mostra 4 altri commenti
