Salta al contenuto principale
Modello A1347 con processore Core 2 Duo da 2,4 o 2,66 GHz.
Check if SMC was reset
I want to do an SMC reset and did so by powering off, disconnecting cable, holding pwr button, plugging in, powering on. But is there a way to verify i reset the SMC successfully? Resetting PRAM/NVRAM is clear because you hear 2 chimes
Questa è una buona domanda?
Punteggio 0
2 Commenti
I'm not sure I follow what you are looking for.
da Condividi
When you do the SMC reset, is there a way to know you did it properly? Like, sound cues, reset date/time or something like that. I want to know if i did it properly
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
A SMC reset null’s the values it holds so there is no means to tell for sure. What is the problem you think an SMC reset will alter?
Punteggio 1
1 Commento:
It was high temps and weird fan controlling. But i think it did reset because the volume changed from max to 50%
da Condividi
Aggiungi la tua risposta
Max Tech sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 15
Tutti i Tempi: 536
