Salta al contenuto principale
Conosciuta come ''PS2'', è una console per videogiochi di sesta generazione rilasciata per la prima volta da Sony in Giappone nel marzo 2000. Negli Stati Uniti è stata introdotta nel 2000 con il modello SCPH-30000. La riparazione di questo dispositivo richiede solo strumenti comuni, ma può essere complicata.
junk in my trunk
How do i get all that crap out of the vent? They say to use a hand held vaccum but that never works!
Questa è una buona domanda?
Punteggio 6
1 Commento
I like your clever title.
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
You could try compressed air. If you do this, though, keep a vacuum near by because the dust will fly everywhere. I run the vacuum right next to the vent, then spray air into it. Compressed air goes in, dust comes out into the vacuum.
Punteggio 4
1 Commento:
The dust that came out of mine was extremely fine, and it was everywhere inside the case. This is an exercise best done out of doors
da
I recently cleaned out an old PlayStation 2 that was purchased off of eBay. I took the brute force approach and opened the case and cleaned each component individually with paper towels and an electronics-safe cleaner. Although a tedious and nauseous operation, the device is super clean now, more so than could be accomplished with a vacuum and compressed air.
Punteggio 3
Use an old fashioned pipe cleaner (fuzzy stuff on a bendable wire). I regularly use these to clean out the crap that builds up on processor heat sinks as well.
Punteggio 2
Aggiungi la tua risposta
Candace sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 20
Tutti i Tempi: 6,135
