Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel giugno 2017, questo MacBook Pro ha processori Kaby Lake fino a Core i7 da 3,5 GHz con Turbo Boost fino a 4.0 GHz.
276 Domande Visualizza tutte
MacBook Pro 2017 screen flickering / glitching / has horizontal lines
My macbook pro screen has started started glitching all of a sudden and I am unsure why. I have tried the following :
  • Restarting
  • Resetting SMC
  • Adjusting display settings
Does anyone have any other solutions for this issue?
Questa è una buona domanda?
Punteggio 8
4 Commenti
Can you post a few pics or vid so we can see what up Aggiungere immagini ad una domanda
da
@danj Hello Dan, I have added some now
da
My MacOS screen now very bad in 18%
Ther some: Flicking, Glitch, Bad Quality, Many Black Screens, Lags and Viruses
da
I hаd a similar іѕѕuе, Mу Mac had flickering lines.
Fіnаllу I mаnаgеd to resolve thе problem after doing some research.
Follow thіѕ guide hеrе: https://smarturl.it/MacFlicker
Hope thіѕ helps
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Not good ;-{
Your T-CON board has failed likely from over heating. Either you tend to use your system on your bed or rug which blocks the vents or you run your system hard playing heavy graphics games or video editing.
Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide Sostituzione schermo MacBook Pro 13" Touch Bar 2017
Immagine MacBook Pro 13" Retina (Late 2016-2017) Display Assembly
Prodotto
$454.99
Punteggio 2
Hi Dan,
I just started having the same issue, so thank you very much for the answer. I have almost no doubt I’ve overheated the TCON board. I have some follow-up questions, whenever you can:
  1. Do you have some idea how much Apple would charge to make this replacement out-of-warranty?
  2. Are the 2020 Macbook Pros (13-inch, Intel i5 processor) set up the same way internally, i.e. with the TCON board between the heat sinks? And are they any better at not overheating? I guess another way to phrase this question is, are the newer Macbook Pros any better at avoiding this issue?
  3. I will definitely look to install a temperature monitor in the future...what is a safe range to have the temperature to avoid running into this issue again?
Totally understand if you're not in the place to answer some of these questions. Any help would be greatly appreciated!
One more quick question: is this issue one that tends to build up over time or can happen in one instance of misuse?
I'm just trying to self-diagnose what processes may have led to this happening.
Punteggio 0
Aggiungi la tua risposta
Sunny Lee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 266
Tutti i Tempi: 23,562
