Salta al contenuto principale
Guide di riparazione e supporto per la terza generazione del Dodge Dakota (2005-2011). Il Dakota del 2005, riprogettato, condivideva la piattaforma con il nuovo SUV Dodge Durango (che ora è simile alla piattaforma del Ram).
Replacing trans cooler lines
2005 Dakota, 3.7, I have trans cooler lines disconnected from trans and cooler but cannot snake them out between frame, engine and trans. Can somebody tell me what needs to be removed, lifted, etc to make room for removal of trans lines?
Thank you in advance for your support!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
You will probably have to unbolt the engine mounts and lift up on it. There are no instructions for this. You will just have to work them through. Leave the transmission mount connected when you disconnect the engine mounts. And first thing is disconnect the battery. No chance shorting anything
Punteggio 0
bend/break the old line. and slide in the new one.
Punteggio 0
Aggiungi la tua risposta
Wesley sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 15
Tutti i Tempi: 2,460
