Salta al contenuto principale
Rilasciato il 26 ottobre 2018. Modelli A1984, A2105, A2106, A2108. Disponibile come GSM o CDMA / eSIM, nano-SIM o dual-SIM / 64, 128 o 256 GB / Nero, Bianco, Blu, Giallo, Corallo o Rosso. (Si pronuncia "iPhone Ten R.")
Which microphone is broken?
Hi, My iPhone XR microphone doesn’t work on speaker calls but works fine on normal calls.
The strange thing is that Siri works fine, (which uses the earpiece mic),… and normal phone calls work fine which i believe uses the bottom mic.
Voice memos just records static, same as speaker calls for people on the other end listening.
Front facing and Rear facing video all record sound fine..What should i be replacing here?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
1 Risposta
Soluzione prescelta
The connector microphones are located on the charging port assembly. One of these microphones has become faulty. I am not sure which one handles the voice memo and speaker phone. Replace the charging port assembly and the audio should be fine.
Punteggio 3
2 Commenti:
Thanks for the quick reply Chris!, ill gave that a go and report back. I had no idea the bottom had multiple mics!
da
Hello please any update
I’m having the same issue
If you fixed the issue how did you do it?
da
Aggiungi la tua risposta
s_joseph_ sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 6,090
