Salta al contenuto principale
Logitech M510, rilasciato nel 2010. Mouse wireless a batterie AA con sensore laser.
Logitech 510 Mouse does not transmit to computer.
The mouse does not transmit to the computer and the “invisable optic” light does not light up.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Try a new battery and check the connections on the battery and make sure the battery is facing the correct direction.
Punteggio 0
2 Commenti:
I tried that--problem is that the LED on the bottom does not light up, and I disassembled the mouse, inspected it, and can not find any obvious issues.
Thanks
Anything else you can suggest?
da
My guess is you need a new mouse. If none of that fixes it.
da
One could try re-pairing to the dongle through the Logitech Unifying Software.
And the “invisible” optic should be indeed invisible.
Punteggio 0
Aggiungi la tua risposta
Bill Seib sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 631
