Salta al contenuto principale
Drone quadricottero prodotto da GoPro per riprese aeree.
Main Board Chip replacement
Hello. I bought this Karma with everything for 150. However, I bought it broken. I located some broken chips. I am good and replacing chips, capacitors, resistors on boards, but I am terrible at the moment knowing what any of it means.
I supplied pictures, could you guys/gals let me know what these are and where I can buy them to reflow them onto the board???
https://ibb.co/BsFMDVp
Immagine
https://ibb.co/dDgKNSN
Immagine
https://ibb.co/bKj8J3W
Immagine
https://ibb.co/7GDbcK2
Immagine
https://ibb.co/f46wx3y
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
you would be better off just buying another one with the pairing issue cheap. The pairing issue fix has a very high success rate. That board could have other issues that you cant see.
Punteggio 0
Img #1 is a 15µH inductor
Img #2 is a 100µF 35V SMD electrolytic capacitor
Img #3 unable to determine if this is a bad connector or bad ribbon cable
Img #5 is a BSC0588- N-CHANNEL POWER MOSFET
Punteggio 0
Aggiungi la tua risposta
rookerdesigns84 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 19
Tutti i Tempi: 271
