Salta al contenuto principale
Modello A2159, EMC 3301. Un aggiornamento del MacBook Pro 13" entry level. Disponibile in argento e grigio siderale. Lanciato a luglio 2019.
Water Stain Under Screen
Immagine
Spilled water on my Macbook Pro this morning. Have fully powered down. Allowing to dry in sunlight. Diagnosis and best course of action?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
The discoloration you notice is because the liquid/moisture damaged the backlight layer of your screen.
No actual electronic components seem to have suffered damage.
Your MacBook will probably keep running normally (depends if some liquid-moisture actually made it to the LCD, corrosion could build up slowly over time and damage the LCD, but it seems like everything dried up)
The only way to fix this is by replacing the full display assembly..
Punteggio 0
Aggiungi la tua risposta
SPat sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 483
