Salta al contenuto principale
La Epson Stylus NX415 è una stampante a getto d'inchiostro a colori. La stampante utilizza cartucce d'inchiostro T088/69/68, che impiegano un sensore di umidità dietro il chip primario visibile.
Error message displayed on printer.
The following error message is displayed on the printer. “ a printer error has occured. Then off the prjnter, then press On button to turn on. See your documentation. “ When this is done the error message is still there, even after unplugging the power and the line to the
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Please tell us the full error message and code if it had one.
da Condividi
It just says error turn off and then on. It didn’t do anything
da Condividi
Aggiungi un commento
1 Risposta
  1. Turn off the printer using the Power button.
  2. Use a pin to press and hold the Reset button at the back of the printer.
  3. Turn on the printer but keep the Reset button pressed for at least 5 seconds.
  4. Release the Reset button after a warning page is printed. After a few seconds, another page with the default IP address of the printer will be printed.
  5. Use this IP address to reconfigure the printer to the computer system.
Punteggio 0
Aggiungi la tua risposta
Robert Passanisi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 42
Tutti i Tempi: 354
