Salta al contenuto principale
Guide di riparazione, smontaggio e soluzione problemi per l'iPad Apple di quinta generazione con 4G LTE, disponibile con 32 o 128 GB di memoria. Rilasciato a marzo 2017. Identificabile dal numero di modello A1823. Dotato di display Retina da 9,7" e processore A9 a 64 bit.
iPad 5 Not Charging
I had a customer bring me an iPad 5 that doesn’t charge. I managed to get it to charge at 1amp sometimes but most times it charges at 0amps…
I checked vchargr and it was showing 4.2volts.. I changed Tristar and now the line shows 5 volt and I also changed charge flex and that didn’t do anything either…. So I tested vbatt on battery connector while plugged in and it shows 1.4 volts instead of 3.7 volts. I looked at a schematic board view for an iPad Air and they are totally different…
I plugged cable in without battery and the amperage goes to about 0.12 amps 0.15amps 0 then moves around but when I plugged battery back in and it boots, it goes back to 0 amps…
Did I install Tristar wrong or is something on vbatt line bringing the voltage down.. When the iPad boots, an I have cable plugged in, it says unlock device to use accessory then starts charging at 0.5amps which should be 2 amps…
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
This is me the author from above.
i am just letting everyone know that I replaced tristar again with a new one and the iPad charges again!
just thought I’d let everyone know in case someone has the same issue as me. Make sure tristar is working !
Punteggio 0
Aggiungi la tua risposta
Daniel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 19
Tutti i Tempi: 491
