Salta al contenuto principale
Repair guides for both film and digital cameras of the now-discontinued Minolta line.
MINOLTA SRT-200 Shutter button issue
Immagine
PLEASE HELP ME. I have a shutter button issue with my Minolta SRT-200. I recorded a video to explain the issue. Thank you in advance : https://youtu.be/uUvUTI81yEY
Questa è una buona domanda?
Punteggio 1
6 Commenti
So the spring is not mounted to the lever. You're lucky!
da
@danj So, is there something I can do? Do I need to mount it? How does one do that?
da
Use a dental pick to drag the hooked end over the lever. Be careful as if you slip the spring can jump off the post to the winds, which is what I had thought you had encountered before.
da
@danj hi dan, i added an updated picture? Did I do this right?!
da
Is it working correctly now?
da
Mostra 1 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
When you cleaned your system you snagged a small spring which holds the stop lever under tension. Looking at the SRT101 service manual which uses the exact same mechanism the spring 3067 is what you lost referencing this guide page17 Minolta SRT101 Service Manual
Punteggio 2
3 Commenti:
Hi Dan,
Does that mean I cannot fix it myself? I Don't believe I broke anything as I was very delicate. Is there anything I can do?
da
The spring is as thin as a hair! And it tends to pop off. Its steel, so a magnet will grab it but as it's so small it can get caught in the rug or cleaning cloth.
You'll need to get a new one somehow.
da
I added a picture, i removed the light meter battery holder, can you see it @danj ?
da
Aggiungi la tua risposta
Emeric Seguin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 14
Tutti i Tempi: 1,176
