Salta al contenuto principale
La fotocamera Polaroid SLR 680 è una fotocamera reflex a obiettivo singolo con autofocus a sonar elettronico integrato e flash.
First shot of a pack gets jammed?
Whenever I put in a new pack of film usually the first shot will get jammed , usually a gentle tap on the side or reinserting the pack works but I always lose that first shot, any advice/help ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
This problem may be caused by a small amount of misalignment in the camera. It concerns a part called “pick” which ist visibly when peering into an empty camera before inserting film. It is in the extreme left corner, a small silvery hook normally feeding the cover sheet or the next picture to be processed just far enough towards the camera´s rollers tofacilitate transport by them. If slightly bent it slips over the cover sheet or the picture frame without facilitating froward motion.
It my be gently bent slightly downwards with a dental pick or likewise to ensure reliable function.
Punteggio 0
Aggiungi la tua risposta
Jason Lopez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 18
Tutti i Tempi: 717
