Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Domande Visualizza tutte
Spilt water on MacBook, but cannot remove battery
I spilt some water which has gone inside the computer. I stupidly tried swithching it on before allowing to dry. It came on shortly and then went off. I have removed the back cover and want to remove the battery as recommended in other solutions. I cannot do this however as I do not have a tri-wing screwdriver.
1 Is it really essential for me to remove the battery?
2 Is there a way to remove the battery without a tri-wing screwdriver?
Questa è una buona domanda?
Punteggio 0
1 Commento
I have managed to remove the battery. Should I leave the bottom cover off while the computer dries?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
A screwdriver from Radio Shack is a lot cheaper than a logic board replacement.
Punteggio 2
5 Commenti:
Unfortunately I live in Zimbabwe and its 9p.m at the moment.
da
Ouch! Now is the time to improvise a tri-wing somehow. You do need to remove the battery. Good luck.
da
What, no Radio Shack in Zimbabwe, what's the world coming to? ;-)
da
Got the battery out with a flat head screwdriver
da
Here's the guide on water damage: Electronics Water Damage
da
Aggiungi la tua risposta
Wilson Luke sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,948
