Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Home button not working
so my iPhone 7 had a cracked screen so I bought an ICloud locked 7 with a good screen to fix mine with, both phones home buttons functioned perfectly fine before the repair, I took the home button original to my iPhone and put it into the replacement screen, and the home function nor the Touch ID is working, I have completely taken apart the home button assembly and put it back together, I have even tried both home buttons and they don’t work, I have also carefully inspected the cables but none have any visible damage, I don’t know what else to do so I’m asking this community
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Let’s call your original phone “Phone A” and the for-parts model “Phone B”.
You say you moved Home Button A onto Display B, and Home Button A didn’t work.
If you put Home Button A back on to Display A, does it work on Phone A? If so, then either Display B is bad or Home Button A wasn’t seated properly on Display B. If not, then Home Button A was damaged during your repair attempt. The Touch ID circuitry is RIDICULOUSLY delicate and very easily damaged.
Punteggio 0
2 Commenti:
The a button doesn’t work on the a screen, I think I might have damaged it
da
Unfortunately that would be my conclusion as well.
da
Have you afther you switch the screen and home-button connected the iphone with itunes and restore it? Sometimes this will help.
Punteggio 0
1 Commento:
No I haven’t tried that
da
Aggiungi la tua risposta
Vipaha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 118
