Salta al contenuto principale
Un sistema di ventilazione meccanica a recupero di calore, o MVHR, del marchio Vent-Axia, è un impianto di ventilazione a recupero energetico.
Fan is oscillating - display dead
Ventilation is going into boost modus and going back to standard, making lots of noise.
I don’t seem to be able to get in the menu, display shows a half bar.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
It sounds like the logic board has failed. The spinning up could be the humidity sensor or it could be the faulty logic boards.
Some systems have a wired controller if this is the issue then you can check the screen on the unit itself. In this case a new remote controller can be added. It would be interesting to know what the issue was as I appreciate you asked this question a while ago.
Hope this helps,
Tom.
Punteggio 0
Aggiungi la tua risposta
Wim Godefroid sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 30
Tutti i Tempi: 534
