Salta al contenuto principale
Processore dual-core Intel Core i5 a 2,5 GHz (Turbo Boost fino a 3,1 GHz) con 3 MB di cache L3 condivisa.
Charge port replacement question
Hi,
My computer has had trouble charging. I replaced the charger (onE of the pins was stuck) but the problem has persisted. I noticed some burn marks on my charge port and and looking to replace it. Which charge port is the correct one? and which repair guide?
my macbook is a A1278 model, serial number is: C1MMHY1KDTY3
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
@tootscoots according to your serial number your MBP is actually a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012
2.5 GHz Core i5 (I5-3210M)
Intro.June 11, 2012
Disc.October 27, 2016
OrderMD101LL/A*ModelA1278 (EMC 2554*)
FamilyMid-2012
13"IDMacBookPro9,2
info from here which would make it a unibody model. Heerr is the guide for that Sostituzione scheda presa MagSafe MacBook Pro 13" Unibody metà 2012 and the part is available right here MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Immagine Replace a damaged or malfunctioning magnetic DC power connector.
Prodotto
$9.99
Punteggio 1
Charging ports are easy to damage. Constant connecting and removal of the connector cord can be hard on the port and move, bend, or damage internal components. Sometimes a dropped phone can also cause charging issues. If your phone or mobile device has stopped charging correctly krogerfeedback
Punteggio 0
Aggiungi la tua risposta
foster anderson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 367
