front camera shows black screen
my iphone shows a black screen when i turn on my frontcam. i changed the frontcam with 3 diffrent replacements and it’s still black. the top speaker does work
can somone help me ?
Questa è una buona domanda?
There would be one more thing you can look at and that is the connector on the logic board. Check there is no damage to the pins; you might need a magnifying glass to check properly.
Other than that it will cost you money as the next step would require a reputable repairer to check the diode readings of the connector to see if there are any open or shorted lines plus check to see if it is getting power. This is not easy as you need the connectors connected and the camera app open.
If such is the case I would recommend this:
If you launch the camera app [SPAM deleted], and see a black screen that doesn’t change, try the following:
If you’ve tried everything above and it didn’t fix your camera problems, then you may have a hardware problem. You should try the following:
I hope this helps!
Regards.
Judy Smith
thank you for your answer. but i did all those steps before i replaced the frontcamera 3 times. the only step i didnt do is bring it to the apple store. an independant repairer tried and failed tho.
its not worth it to pay more than a 100 euro's to fix the phone, i would like to fix it myself but i cant find the solution.
I did all that but it’s not working
Assuming you've exhausted all of the possible software options up to and including a complete DFU mode restore of the phone, then the next logical step is to replace the camera.
Sostituzione fotocamera anteriore e cavo sensore dell'iPhone 7
If you've done that and it's still not working, then you're in the same situation as the original poster where you'll need to check the logic board connector followed by board level debugging.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 4,970
