Salta al contenuto principale
Repair guides and support for the 27" Dell UltraSharp U2711 external display released in February 2010.
How to use iMac monitor stand on VESA VGA monitor
I bought a Digitech Computer Articulating Desk Mount with bracket (model CW-2870) because its cheap. But I want to use it to mount a VGA monitor that is VESA-compliant ! How do you do that?
Update (01/13/2020)
This is the Digitech Computers’ CW-2870 from JayCar
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
It looks like I need to improvise. Oh well, here goes:
  1. First, source a stainless steel strip to ‘construct’ an iMac-like mount
Immagine
** This will then be mounted on the VGA monitor’s VESA-compliant mount
Immagine
  1. procure some nut/bolts
Immagine
  1. drill holes onto the stainless stell strip and attached it to iMac mount of the DigiTech articulating arm with the bolts.
Immagine
  1. Secure these on to the VESA mount of the monitor
Immagine
  1. mount the assembled iMac attached to the VESA mount of the monitor onto the monitor
Immagine
  1. mount the monitor to the articulating arm. Secure with provided allen screw
Immagine
All done !
Immagine
Punteggio 2
3 Commenti:
Hi @junmac ,
Pretty nifty. ;-)
How about you create a guide for others down the track who may not find this post
Dare To Repair: How To Create a Guide
Cheers.
da
@jayeff
Hope you (and others) find this guide useful
How to mount a VESA monitor on an iMAC monitor arm/stand
Jun
da
Hi @junmac ,
Thank you
da
Aggiungi la tua risposta
Jun Mac AUS sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 22
Tutti i Tempi: 544
