43lh604v screen very dim
I have this LG smart led TV and the screen is dim .
What ever color setting I do , make no different .
Then the eco mode off as well .
Does it require back lights replacing ?
Questa è una buona domanda?
@awais21 it depends on how dim dim is. Most likely it is a backlight array issue since LG has a lot of trouble with that on their TV’s. You can try and post some pictures of what your screen shows so we can see what you see. Aggiungere immagini ad una domanda If you cannot or nothing would show since the screen is to dark , I would get a new backlight array and replace it. Bit of a PITA to do it since you have to disassemble the panel, but it is not terribly difficulty. Just get a hand handling the panel once disassembled so that it does not flex on you and crack.
Can you see the picture I uploaded
Hello sir I have added a picture .
I checked the back light 3 strips are coming 30 pounds used on eBay but I can't find any videos for this TV and not sure if I can change it myself .
Hi @awais21
Your pictures are not there.
You should be able to see them yourself when you post them as an edit to your question Click on Options > Edit and then click on the insert an Image icon at the top of the edit box
Here's a link to the service manual for your model TV.
You have to buy it but in the end it may be worthwhile if you can't find any other information about disassembling the TV.
I think I have done it now . Most likely I will put it on eBay and see how it goes
Its hard to tell what the problem is exactly with the one picture you have posted. Maybe a few more from different angles? Different pictures on the screen?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 309
