Salta al contenuto principale
Repair guides and support for your LG TV.
1341 Domande Visualizza tutte
Why my LG TV Screen flickering and displays horizontal and vertical
I bought LG UHD 49inch 3 years ago and now the screen diplays horizontal /vertical lines .As per LG Technician i need to replace the panel . Kindly advice do i have to replace the panel , if so where i can order the item through online. LG tech team removed the cables after opening the back cover of the TV and reconnect but still the issue remains same.
LG49UF671T
Questa è una buona domanda?
Punteggio 0
3 Commenti
Based on the image on the screen repeating itself several times vertically, I would pop open the back of the TV and look for swollen capacitors on the main board and power supply. Noise on the power supply rails can easily cause all sorts of issues. Does the symptom change as the TV warms up? Did it get hit or dropped?
da
TV was not hit on anything and it was running smoothly. Suddenly a line appeared and eventually spread across the screen after 2months. LG technicians and a local technician suggested to replace the panel. I was using for last 4 years and this was the first issue noticed now.
Once I turn on the TV screen start flickering with many lines.
da
what happened? our tv also just started flickering all of a sudden, as per my nephew it was working fine it just happened. how did you resolved this issue?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@shan321 it is easily possible that this “screen display horizontal /vertical lines” is a bad panel. LCD panels like the one you would possibly need are not easy to come by. You will need to do an online search based on the label on the back of the panel not your TV model number. The panels may have had revisions etc. which can cause issue for the replacement, thuis make sure you look for the same panel number as you currently have. You can also try and see if you can find used ones on places like ebay, craigslist, pawn shops etc.
Post some pictures of what your TV displays so that we can see what you see. Aggiungere immagini ad una domanda
There is always a possibility that it may only require a new main board or t-con board
Punteggio 2
4 Commenti:
Kindly check the pics
da
@shan321 does your menu still display normal? right now it looks like the time on the top left side of your screen looks normal. Let us know if it does since then there is a possibility that it is a main board issue.
da
@shan321 as for a replacement, you’d be looking at something like this. You can of course check individual places like this to see if they sell to customers or strictly wholesale.
da
@oldturkey03 Thanks a lot
da
Aggiungi la tua risposta
Shan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 51
Tutti i Tempi: 9,653
