Nexus 5X does not turn on after battery swap but screen shows charging
I recently replaced a swollen battery in a Nexus 5X. The phone powered up and operated normally with the swollen battery. Upon replacing it with this battery from amazon: (https://www.amazon.com/dp/B01H40OF4U/ref...)
…the phone no longer turns on. It does show the battery charging imagery on the screen.
I left it to charge overnight, and while it shows me it’s charged, the power button does nothing.
Looking for some advice and troubleshooting steps. Thanks.
I already disposed of the swollen battery at Home Depot’s disposal bin. I didn’t want a swollen battery in my house.
Questa è una buona domanda?
2 Commenti
Hi,
You may have to go back in and check your work.
Check that the Power button actuator is working correctly and that there are no problems around that area, e.g. loose or broken connections etc
da jayeff
Thank you for the reply Jayeff. I took the phone apart tonight and left it apart with the battery disconnected for further inspections. I removed the rubber button and checked it as best I could with a magnifying glass. I don't see any obvious problems.
Would it be possible I have received a bad battery? I guess it wouldn't be an expensive experiment to purchase another one.
da Raven Hurst
