Why is my TV malfunctioning?
My TV started displaying different functions by changing the colour mode, volume etc
Questa è una buona domanda?
Hello Badejo
If nothing helps as described in the comments, try the following:
1) Unplug from the wall socket, wait 10 minutes, plug it back into the socket.
2) If this does not help, reset the TV to factory settings (see user manual).
3) If this still doesn't help, consult the service manual.
Good luck,;
Homer82
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 133
Can you post a short vid (or pics) of what you are seeing Aggiungere immagini ad una domanda
da Dan
Hi,
Try removing the batteries from the remote control unit and check if the problem is still there or not.
If it stops then there is a problem with the remote
da jayeff
