Salta al contenuto principale
Guide di riparazione e assistenza per il OnePlus 5T, uno smartphone Android con display AMOLED da 6,01". Rilasciato a novembre 2017. Successore del OnePlus 5. Numero di modello: A5010.
Oneplus 5T - Motherboard FPC pin Problem!
I've had this oneplus 5T where I cracked its screen(intentionally… /face-palm), tried fixing it myself, ended up in a total failure and this is how I ended up damaging the motherboard pin, where the USB cable connects.
Now I took a calm approach, and want to fix it again, I have all the necessary tools, but I have 0 soldering skills, so please check the images, and tell if it's possible, and give me some guides or something… thank you
Immagine
Here you can see the torn pin
Immagine
Torn part from the pin
Immagine
Here I cleaned up the area
Immagine
This is the new pin I've ordered
And here are the Tools I have
Immagine
Immagine
Is it possible to fix this??
Questa è una buona domanda?
Punteggio 1
3 Commenti
If someone have a dead oneplus 5t I would like to try to change this fpc connector practice make men perfect so if anyone have fully dead phone or motherboard issue let me know will try fix it. If it gets fixed it’s free for you.
da
have the same issue. Where have you found the parts..?.. which website you buy FPC connector..?
da
Hey were you able to fix it finally.
I screwed it up the same way.
Please mail me inorockdude@gmail.com. truly will appreciate it
da
Aggiungi un commento
3 Risposte
Risposta più utile
100% That is possible to fix, practice in another phone for parts, if you purchased all that stuff you can purchase a phone for practicing. Until you do a clean job you can do it on your good phone.
With a Soldering pen with angle on the tip and enough flux you can do a good job.
Punteggio 1
5 Commenti:
@conlledo This was my main phone 2 years ago, now I want to resurrect it, I've watched a lot of guides on this, and I will try and do it on this phone, with extreme patience.
I dont have have the Flux from my bag of tools but I've already ordered it, and also waiting for the pin to come, I will definitely give an update soon.
da
Find a board, any old board (Computer, Toy etc) and try to remove and put back components that helps to know your soldering pen. also does the soldering pen has temperature control?
da
That's a very good tip, and yes the soldering has a temperature control, 300 and something should be used from my understanding, no?
da
That you see the FPC is a plastic piece, and if the tip is too hot you can destroy it, so you have to choose the right temperature and right tip to complete the job.
da
Did it work out? I have the same issue. Where have you found the parts?
da
I've had only problems with this phone, mine was never the same, I repaired it, I've sent it to oneplus for a trade in Programm and they never responded back…
To answer your question, I found it on a UK website but it costs 16£…
To give you a friendly advice, never settle.
Punteggio 1
1 Commento:
would you please provide me with the website that you got the FPC from? i am facing the same issue and couldnt find the chip. my email is bilal.haji@gmail.com
da
Bro pin kaha se mile
Punteggio 0
1 Commento:
aliexpress mein available ho
da
Aggiungi la tua risposta
Macarovici Dan Andrei sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 44
Tutti i Tempi: 2,144
