Salta al contenuto principale
Il Cruzer Blade è un'unità flash USB 2.0 rilasciata da SanDisk.
Write protected pendrive issue
my pen drive has been write protected, format related issue.
I did everything like in registry edit, cmd command, used tools, but the problem remains same
Questa è una buona domanda?
Punteggio 24
2 Commenti
Have you attempted to use any kind of write protection removal or partitioning tools?
da Condividi
usb write protected problem
da Condividi
Aggiungi un commento
5 Risposte
Risposta più utile
First I maked the bootable USB of Ubuntu then I installed Ubuntu in dual boot successfully, but now I am formatting my SanDisk USB then it is showing me error of " write protected". I tryed most of the ways from Google but that is not working, my USB is also showing in disk manager but, I am not able to format or delete the partition, can you help me please 😢🙏
Punteggio 4
Download Ease partition primary
And click own write protection clean
It will scan usb and clean its write protection problem
Punteggio 3
1 Commento:
Is This One Really Working?
da Condividi
Sadly there just isn’t any way to salvage your USB drive.
Punteggio 1
Possible causes of read-only mount:
  • Security configurations on the Operating System; Too many to list, but they are altered using Windows Registry; Google around;
  • Corrupt Filesystem / Dirty Bit set; Use chkdsk;
  • Corrupt partition table; Use a drive partitioning utility; Pendrive will be erased but will be usable later;
  • Pen drive microcontroller reporting faults; It means it’s time to buy a new drive. I’m still looking into possible temporary fixes to make the drive last a few more days, but it looks bad.
Punteggio 0
1 Commento:
da Condividi
Its seems that Cruzer Blade usb disk is awful. I have the same problem “write protected” and I have found many other posts in internet with the same problematic usb disk.
Punteggio 0
Aggiungi la tua risposta
Rohit Dharan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 57
Tutti i Tempi: 6,385
