Salta al contenuto principale
Un dispositivo audio generico che trasmette le basse frequenze audio alle tue orecchie.
Only 1 amp working!
I have 2 amps set up everything is wired up good I checked all my volts with a multimeter ,and everything checks out . But it seems that I can only have 1 amp wired to get any power . I wired each of my amps to 1 power source and each amp started up so is there a reason I can’t set up my highs amp and my bass amp ?
Questa è una buona domanda?
Punteggio 0
1 Commento
@jaimeibarra what make and model are your amps. How did you wire them up? Schematic or picture?
da
Aggiungi un commento
1 Risposta
Risposta più utile
There might be an issue with the remote turn-on lead. Some radios don’t provide enough current out of the remote lead to turn on multiple amps. Try running 12V from the battery to both of the amps remote turn-on leads and see if they both turn on. If that works, then you can use a relay connected to the radio’s remote turn-on lead and switched 12V power to switch your amps on. Also check to see if you get a voltage drop when both amps turn on at once. It’s possible that one of the amps is going into protection mode due to under-voltage. There could be a wiring, car battery, or alternator problem that isn’t supplying enough current for all your car’s electronics.
Punteggio 1
Aggiungi la tua risposta
Jaime Ibarra sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 33
Tutti i Tempi: 442
