Salta al contenuto principale
La versione da 7" della nuova serie di tablet di fascia alta di Amazon, rilasciata nell'ottobre 2013. Modello C9R6QM.
Nothing when turned on
I haven’t used this device in many years and it probably is due to the battery but there is no low battery icon when power button is pressed/held (it is dead) and I want to know if it’s safe to charge or if it will even do anything if charged.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Over time a devices battery will die or drop to 0% if it goes under you will need to recharge them with a special board. I have seen this behavior on an iphone se charge it and see if it charger take precautions though battery may be acid leaking like a AA does in cold weather or when it gets old. Hope you find this response helpful.
I’m 15 so im not the smartest thing on here.
Punteggio 0
Aggiungi la tua risposta
Biggie Cheese sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 17
Tutti i Tempi: 327
