Salta al contenuto principale
Il Dell Alienware M14x è un computer portatile progettato per un'esperienza di gioco e di contenuti ottimale.
Laptop GPU reflowing- help needed
Hi I want to reflow the gpu on my only laptop by myself, I can't trust repair center or can't effort a new laptop .
I kind of bent the main board so this happened.
Question : I want to reflow gpu using heat gun and laser thermometer for measurement , what's the best melting temperature for it? I saw people go up to 260 but I usually solder joints melt at 200-210 Celsius , so I'm wondering if lower temperature will reduced the risk of burning the gpu completely…
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@javid_zare_s a reflow is not going to fix a bend motherboard. If the solder connections or pads have come loose they will not go through a reflow. Remember that a good reflow is more than just blasting an area with a hot air gun. Anyhow, I suggest you follow the profile as outlined on here
Punteggio 1
Aggiungi la tua risposta
Javidzed sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 7
Tutti i Tempi: 682
