Salta al contenuto principale
Calcolatrice scientifica di Casio. Ampiamente utilizzato dagli studenti di tutto il mondo grazie alla sua grande qualità e per il prezzo basso.
How do I fix my calculator that only runs on solar power?
My Casio fx-991ES PLUS was dropped and now the display does not light up unless it is under a light source. It has a mini solar panel which I assume it using for power and it has new batteries in it but they do not seem to work. Is there something I can do to fix it?
Questa è una buona domanda?
Punteggio 7
1 Commento
I replaced mt calculators
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
@madrthanevr could simply be an issue of torn wires/ connectors or something more sinister like an issue with the power management IC on your PCB. We’d need to see what is going on inside your calculator Aggiungere immagini ad una domanda
Punteggio 4
3 Commenti:
Thanks @oldturkey03 there was just a disconnected wire. Probably should have checked beforehand. Much appreciated!
da
My casio MJ-12D is not working after putting in sunlight.....what should i do for this??
da
@madrthanevr how did you check the wiring? I have a similar problem
da
Casio can replace the broken screen, they will give you a price before they do the repair, by the time you add shipping to them and shipping back to you, you will be better off just buying a new calculator and keeping this one for spare parts for the next person who wants to buy a motherboard.
Punteggio 0
Aggiungi la tua risposta
MadRthanevr sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 39
Ultimi 30 giorni: 118
Tutti i Tempi: 27,516
