Salta al contenuto principale
Lo smartphone al top di gamma Huawei lanciato nel aprile 2018. Modello CLT-L29
My P20 Pro only has service when plugged into a charger.
I took my phone to a repair shop as i completely smashed my screen.
He managed to replace the screen but now my phone will only connect to Vodafone network when plugged into a charger.
If i remove the usb from the charging port it goes to no service
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like the battery may have gotten disconnected and/or died.
Sostituzione batteria Huawei P20 Pro
Punteggio 1
3 Commenti:
Changed the battery and still the same issue. Replaced the Antenna as well. Any other suggestions?
da
@jayb_1991
I'm facing the same issue after replacing my battery's
were you able to solve your issue ?
da
Hi, same problem for me. After battery replacement, signal is ok only under charging or if I connect hear jack. Any suggest?
da
Aggiungi la tua risposta
jayb_1991 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 716
