Salta al contenuto principale
Questo Apple Cinema Display è identificato dal numero di modello M8149 ed è stato rilasciato per la prima volta nel luglio 2000
Erase mark on screen?
A Sharpie permanent marker touched the screen of one of my Apple Cinema Displays, leaving a mark about an inch long. Does anyone know the best way (any way) to remove such a mark with no (or the least possible) damage to the screen?
Maybe a chemical that will react with (remove) the black mark while not harming the display (or not too much), applied with Q-Tip or something? Magic Eraser? Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Use a LCD friendly spray to do it. Alcohol works too. For Sharpie, I'd use alcohol first since it usually works. Rubbing the screen would work too, but be careful what you use to do this. Some things damage or scratch the panel.
If this doesn't work, then leave it. You'll do more harm then good.
Punteggio 3
2 Commenti:
+ for the editing..try for the fourth, it's subtle..
da Condividi
Anodex is a product that seems to be highly recommended. Anyone have any experience with it?
da Condividi
Aggiungi la tua risposta
John Brandt sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 21
Tutti i Tempi: 1,212
