Salta al contenuto principale
L'Apple Watch Series 1 è una revisione dell'Apple Watch originale ed è stato annunciato il 7 settembre 2016. La maggior parte dei componenti è la stessa del Series 2
Horizontal lines going through the screen
I recently toon my screen off. When reattaching it, the display have horizontal lines going through the whole screen. What would needs to be replace in this case?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione prescelta
Ouch!
You managed to damage the display. The cost of a new display is about $85 ~ 120 depending on the size and glass.
Apple just lowered the price of the Series 3 depending on how worn yours is you might consider it.
Punteggio 1
5 Commenti:
Well the watch is a series 1 42mm. So the screen shouldn’t be too expensive.
da
have you managed to fix it? I have been the same problem after changing the force touch sensor?
da
@Abhishek Kaushik - I'm sure replacing the display solved it!
da
Do you know where can I find the display?
da
@Abhishek Kaushik - They are becoming hard to find, sorry I don't have a source to offer you.
da
If you struggle to find a new screen look on eBay for a spares or repair watch the same as yours with a good screen and use that. Cheaper than a new one too. I used to repair fitbits this way.
Punteggio 0
Immagine
This is what it looks like, so I’m not sure if I messed up the display or the connectors.
Update (10/05/2022)
When powering on it looks like this
Immagine
Punteggio 0
Aggiungi la tua risposta
Tyler Young sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 46
Tutti i Tempi: 4,170
