Salta al contenuto principale
Smartwatch Motorola Moto 360 2nd Gen prodotto da Motorola Mobility nel 2015. Smartwatch indossabile che si collega al tuo telefono.
Battery Replacement 6 pin spanner
Doing a battery replacement for the Moto 360 2nd Gen and I’m stuck at the part which requires me to remove the button. Is the 6/3 pin spanner sold anywhere? Is there a replacement that I can get?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
part number: IF145-373-51
description: iFixit Precision 4 mm Screwdriver Bit / Spanner 6.0
cost (as of today) $2.99
Make sure you select ‘Spanner 6.0’ before adding to cart! The drop-down has all available bits in it.
Immagine iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit.
Prodotto
$2.99
Punteggio 0
2 Commenti:
This tool is nothing to do with removing the button on a 2nd gen moto 360. So this is both annoying and misleading
da
I'm sorry, I found this to be the closest thing to help me remove the button. Is there a better way or better tool?
da
Aggiungi la tua risposta
Dacheng Li sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 5
Ultimi 30 giorni: 13
Tutti i Tempi: 603
