Salta al contenuto principale
La HP Officejet Pro 8600 Plus è identificabile dal suo numero di modello: N911g. Pubblicata nel 2011, la stampante può essere identificata dalla sua finitura marrone e dal pannello di controllo touch.
What is a printer failure?
It said “printer failure,” but I don’t know what happened that caused it. It said,
Printer Failure
There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP.
Then I took pictures:
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
1 Commento:
Evan, have you received any offline replies? I have this exact issue with my OfficeJet Pro 8600 Plus, using my Mac that's running OS X 10.14.4. I've done all of the suggested troubleshooting too, and now I can't even run the HP EasyStart app to check if the firmware is up-to-date b/c even tho the wifi icon is lit up on the display, EasyStart can't find the printer on my network. And I can't get beyond the "printer failure" message on the display...!
da
Aggiungi un commento
1 Risposta
Sure looks fine internally.
Have you tried the troubleshooting steps on HP’s support site? My gut tells me there might be paper stuck in the duplexer. I’ve had that same model printer and it seemed like it was getting choked with paper constantly.
Punteggio 0
Aggiungi la tua risposta
Evan Lei sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 28
Tutti i Tempi: 1,592
