Salta al contenuto principale
La Sony α6500 è identificabile dal modello ILCE-6500. È una fotocamera mirrorless digitale con attacco E e sensore APS-C. La Sony α6500 è stata rilasciata nel novembre del 2016.
Sony 6500 Base Damaged
The Base of my Sony 6500 was damaged in that a tripod screw broke inside the camera body and now the camera cannot be used on a tripod as the screw cannot be removed. Is it possible to have that bottom OR the complete outer camera replaced
Questa è una buona domanda?
Punteggio 0
1 Commento
I'm not sure how different the models are but here is a disassembly video of the A6000. Hope it helps!
https://www.youtube.com/watch?v=y3CCJtD0...
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hey Douglas,
I had a similar thing happen with my a6000 a while ago. You could opt to replace the outer housing, but depending on how well the tripod screw is lodged, it could be removable with no disassembly. I covered the bottom with painting tape and made a hole in the tape where the screw is is. I then used a small bolt about the size of the hole, put a small dab of glue on it, and let it set. Once it set for a long time and hardened, I simply twisted it out.
Hope that works for you, best of luck!
Punteggio 1
Aggiungi la tua risposta
Douglas Quick sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 611
