Salta al contenuto principale
L'HP Compaq 6730b è l'edizione "business" della linea di portatili 6730 rilasciata da HP.
Why doesnt my computer turn off
why does my computer not turn off ?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Have you tried holding the power button for 5 or more seconds?
da
Aggiungi un commento
2 Risposte
The following command will completely shut down your computer in Windows:
Right click Start icon and select Command Prompt
Type or copy/paste the following in that window:
C:\Windows\System32\shutdown.exe /s /t 0
After your computer has shut off, restart it again and then try testing shutting down as normal.  If computer still won't shut down, please post what operating system the computer uses and your method for shutting the computer down.
Punteggio 0
use forced turn off i.e
1-hold power button for more than 5 seconds
2- use command prompt shutdown
3- you will be forced to remove the battery if the laptop is completely unable to shut.
Punteggio 0
Aggiungi la tua risposta
Ray Hagen sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 8
Tutti i Tempi: 532
