Salta al contenuto principale
Informazioni di riparazione e soluzione problemi per trattorini tagliaerba a marchio Craftsman.
mower wont move when started
My T150 mower is new this year. I got a skinny stick caught between the mower deck and mower. It appeared to be wrapped around a metal rod. After I dislodged the stick the mower started but will not move. I am a 62 yr old widow and have NO idea how to fix it. Any suggestions would be appreciated.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi,
My first thoughts are that it is the throttle pusher or the parking brake. Can you let me know if you can rev the engine, and if it is in neutral?
da
Aggiungi un commento
1 Risposta
Broken or stripped gear in rear axel assembly, if it is not as simple as a broken belt. More expensive to fix than it's worth.
Punteggio 0
Aggiungi la tua risposta
Mary Helsel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 9
Tutti i Tempi: 164
