Salta al contenuto principale
Una console videogame ad alte prestazioni creata da Microsoft, dotata di grafica 4K. Numero di modello: 1787
TDP 158 hdmi chip
I was wondering if the HDMI chip is the same in all the xbox. i have the scorpio edition. I am no longer getting a signal from the xbox to the tv. What is the process for replacing this chip? does it just snap out and snap in? Any info would be great. It would be nice if they posted all the part numbers for each edition of the xbox.
thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Not quite snap out snap in unless you consider replacing the motherboard be such a procedure! :-)
See https://d3nevzfk7ii3be.cloudfront.net/ig... where the surface mounted chip is located just above the hdmi ports located on the motherboard
Punteggio 0
Aggiungi la tua risposta
Chris Conner sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 14
Tutti i Tempi: 829
