no power to drain pump
Hi i have top load lv washer, that would stop at the spin stage and roll slowly untill OE error comes up to say the water is not draining. I have checked hoses and even replaced water pump thinking it was the problem. it was not; both pumps are working if plugged directly into electricity. Infact if i plug the pump into my own power source the water drains really fast and the washer happily enters the last spinning state. So i tried to measure V across the plug that supplies the pump with power and its showing 60V potential (pump sais its 120V) i wonder if there is something like a burnt fuse i can replace (though my fear is its some regulator directly on a washer pcb) any thoughts?
(ps both pumps tested while washer attempted to drain by powering pump directly with 120v which worked as expected but not when pluged into the washer hatnest)
Questa è una buona domanda?
6 Commenti
Hi @ds21
What is the model number of your washing machine?
Also did you mean to say LG?
da jayeff
Yes, LG sorry, from memory I think WT1201CW. Basically it werks "perfectly" if I give the drain motor external 120V when machine tries to drain; water goes away and it starts the spin s cycle.
da Daniel S
I did buy replacement motor before I tested old one, both are in working condition :/
da Daniel S
hi my model is Samsung wf702w2bcsd did't have power in to drain pump water out
da chanthet bo
before buying new pump (unplug the power) . take the back off and disconnect the pump, and "don't" make custom attachments to plug it in (mine ran on 110) to see if it is the pump. On mine I ended up powering it separately for draining until replaced the washer
da Daniel S
Mostra 1 altro commento
