Salta al contenuto principale
Il telefono-con-stilo al top di gamma della Samsung, successore del Note8, lanciato nell'agosto 2018. Ha uno schermo da 6,4" e fino a 512 GB di memoria interna.
Wrong file TWRP bootloop
Hi,
After install TWRP from Odin my Note 9 was stay on bootlop 'Samsung Logo' and restarting, i can't go to Download Mode and Recovery but phone only restarting bootloop.
It happend after install wrong twrp files (\twrp-3.3.1-1-star2qltechn.img.tar) i have select on Odin "Rebooting"
What's going now? Regards Thank you for help
Recovery and Download doesn't work, i can't going to him.... only restarting *****
video: https://streamable.com/k242c
Questa è una buona domanda?
Punteggio 1
2 Commenti
Hi Eda Ea, did you able to fix the problem , I faced the same one
da Condividi
Hi eda ea
i have the same problem
were you able yo fix your phone?
if yes, could you please tell us how?
thank you
da Condividi
Aggiungi un commento
3 Risposte
Risposta più utile
Turn it off full power off take cable out hold volume and Bixby whilst holding plug in USB
Punteggio 2
2 Commenti:
After a failed attempt to remove the battery and ending up cracking the back glass, what you said was the solution. Just ONLY hold volume up and bixby, then plug in the USB. Thank you very much!
da Condividi
i cain't turn off my phone it just go off and on on logo after it's off i plug it in and it starts again. holding buttons doesnt help
da Condividi
Hi Eda ea !
There is always a risk when ROOT a smartphone.
Did you try the recovery mode with the following commands :
Volume Up + Bixby + Power key together for a few moments
Immagine
Punteggio 0
4 Commenti:
I waiting for battery runs out of charge.  And push Volume UP + Bixby + Connect Cable USB, was starting to Samsung logo and bootloop…. i installed TWRP from other model (A6+) my misstake… and have select option in odin Nand Erase and Auto Rebooting…
da Condividi
Indeed, if the wrong TWRP model has been installed.
A reset factory will have to be done.
I suggest you consult this link: https://www.hardreset.info/devices/samsu...
da Condividi
Not possible it’s same problem….
da Condividi
If even this procedure does not work, I am afraid there is no other solution, unfortunately. Maybe another member will have a second solution.
Good luck with that!
da Condividi
please help me i have the same problem
Punteggio 0
Aggiungi la tua risposta
eda ea sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 31
Tutti i Tempi: 1,528
